SOURCE: Jack LaLane Power Juicer CL003AP Tri Star Products
The Jack Lalane website claims it has a lifetime engine warranty. Visit to find out.
SOURCE: Taking apart Jack Lalne power juicer to clean.
There are two holes on the surface of the blade. When the juicer was bought, it came with a half moon shaped orange tool that has two posts that fit into these two holes.
By inserting the tool into these holes you can unscrew the blade from the machine as long as you hold the outer screen while doing so.
Once this is done, you simply lift the other pieces off.
If you can't find your orange two prong tool, i would suggest using a screw driver or two that fit into the hole(or two)..... hold the orange screen and turn the blade counter-clockwise..
Hope this helps
Smitty
SOURCE: How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
SOURCE: I cannot dissassemble the blade and other parts of the jack lalan
http://www.powerjuicer.com/customer-manuals.html
This is the site to download User Manual, Instructions and troubleshooting Guide.
