SOURCE: GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
SOURCE: GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
SOURCE: GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
SOURCE: GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
