SOURCE: singer futura CE-100 4 blinking reds lights
same thing with mine. it stops after 8 stitches every time. now if i use it, i will go for 7 stitches, then let off the presser foot, and start again for 7 stitches. i've tried everything.
SOURCE: Futura 250
Remove your foot control Mine has never been connected while I do embroidaring. Never had I problem.
SOURCE: hoop errors
I have the same machine 1 year old ,check thet the hoop is on pins correctly and tight and that the large hoop is selected on the program.as these machins are verry sensetive.Hope this helps.
Lea
SOURCE: singer futura XL400 thread breaking
Unthread the machine and start from scratch. After rethreading make sure your spool of thread has free play at the reel (not caught on anything) then check the thread tension make sure it's not too tight. Also check the bobbin is in place correctly and the bobbin has been wound correctly not too tight. If it is still happening it may be an adjustment to be done by a tech? Also try different threat, faulty thread can do that as well.
