Miscellaneous Logo
John Willett Posted on Mar 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to reset the ink absorber on a Canon mg6120.
I have cleaned the pads, but can't reset the aborber, so I keep getting the warning
Marvin
Level 3:
Top Expert:
  • Miscellaneous Master 85,242 Answers
  • Posted on Mar 27, 2019
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024340
Points
266281
How do I reset my Canon ink absorber? Insert new ink absorber pads firmly into the rubber frame. Replace the rubber frame in its original position and close the printer. Hold down the power button, then plug the printer back in. Continue holding the power button down until the printer begins to reset itself and come online.
5 Related Answers
Anonymous
  • Posted on Nov 30, 2007
SOURCE: Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
hanafi
  • Posted on Jan 24, 2008
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Anonymous
  • Posted on Mar 12, 2008
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
CAM THE MAN
CAM THE MAN
  • 20 Answers
  • Posted on May 27, 2008
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Anonymous
  • Posted on Apr 01, 2009
SOURCE: Reset Waste INk Canon MX318
help me please....!!
may printer error 5B00
5helpful
My Canon MP210 printer [ USB001 ] said the Ink absorber is Full contact the service center. Guess what, the service center just gave information. I need to know if will be able to fix or will...
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. There are actually two absorber pads located on the right side of the printer, under the
ink cartridges when the carrier is in the home position.
Accessing the pads and remove them for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezers and extra cloth for some ink spillage. Using the tweezers, lift up the pads sitting on the rubber retainer. The pads can be easily clean by placing them under running water. Use warm water to remove the ink from the pads. Dry the pads and reinstall them. Same procedure if you are installing new pads.
However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
3. hold the Power button, release Resume Button.
4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
7.
Please rate this solution. Let me know if you have any more questions. Thanks.
14helpful
2answers
Ink absorber full on a canon mp190
my canon Mp 190 ink absorber all most full. How to do?
3helpful
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
The waste ink absorber is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
2helpful
I get a warning that my "waste ink absorber almost full". How do I empty it?
Can you tell me what unit is your canon printer?
Because there are two ways to clear the waste ink absorber full in your printer.
First, is by actual cleaning of the ink absorber pads that is seated under the ink cartridges in its home base position. Remove the waste ink from the foam / pads by a running water.
Second, is by a reset procedure..but I cannot give you the exact reset procedure because you did not mention the model of your canon printer.
Please reply back so I can help you further.
Please rate this answer if were done with your solutions.
Thanks.
3helpful
4answers
I am getting the warning "Ink absorber full". Is there anythinh I can do on a DIY basis?
Hi
Thanks for using FixYa. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. You can locate the waste ink pads to the right of the cartridges. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. You can reset your Canon Printer by following this procedure—
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button 4 times for waste ink counter reset.
5) Turn off the printer.( it must be turn off) then turn it on again.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
3helpful
2answers
Ink waste absorber is full. Canon IP2000. How do I repair it?
Well, at some point you will need to either replace or wash the absorber pads in the printer - but you can reset the warning as follows:
1) Turn the printer off
2) Press and hold the <resume>button
3) Press and hold the <power> button
4) While holding down <power> release <resume>
5) With the power button still held down, press <resume> twice more
6) Release the power button
7) Press and release the <resume> button 4 times
8) Press and release the <power> button twice
At this point, the printer should come back online with the waste ink warning reset
Personally, I would only do this once before actually changing the ink absorber pad...
98helpful
6answers
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
3answers
Canon Pixma MP780
Yep your printer is nearing service time. This involves changing the waste ink pads and resetting it.
you could reset the printer without changing the wate ink pads but you risk damaging it
What i do is take the pads out wash them and replace them.
the waste ink pads are the pads the cartridge rest on whan itsn in neutral position
THE SERVICE MANUAL FOR YOUR PRINTER *step by step instructions in repairing it) is here
http://www.nodevice.com/manual/Canon/page15.html
and here
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
enjoy
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
