It might be a loose drive-chain or band.?
It might just need a good service.?
You'd service your car to keep it running properly & the petrol engine in the buggy is just the same.?
It needs the air filter checking (clean or replace.?)
It needs the fuel filter checking (might be an inline filter or it might be inside the carburettor where the fuel line entres it.?)
(There might also be a filter on the end of the pickup pipe in the tank. That just pulls-off to clean with hot water & washing-up liguid or a degreaser.?)
It needs the spark plug checking (clean plug head or replace plug, correct plug gap.?)
Make sure the exhaust isn't blocked with any crud or anything
If it's a 4-stroke engine, make sure the oil is topped-up at the same time you're checking everything else over.!
SOURCE: 1996 Ford Explorer vibrates when idling. Also...
You have a hesitation. A hesitation is cause be either:
1. bad spark plug
2. bad spark plug wire
3. bad or leaky or plugged injector
4. timing is off
5. leaky vacuum hose
SOURCE: 110cc aeon cobra losing power
sounds like clutches need maintainance.other things could be a stretched belt.bad plug.partially blocked exhaust.but usually a worn clutch is most likely the cause.you can check the belt while you are there
