It should unlock once the temperature has dropped to a safe level. If its still locked after that time, I would say the safety lock has failed to release and will need replacing. I think it will need accessing through the top to manually release the door latch mechanism.
I understand your Electrolux oven is continuously beeping. Without knowing your specific model number, let's try resetting your oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your oven. If resetting the power does not correct the issue, then your range could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. Hope this helps! - Z
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
I understand you having trouble getting your oven to work after using the self-cleaning mode. Does any part of the oven work? Confirm a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc.
Does "Loc" appear in the display if any button is pushed?
The Oven Lockout feature automatically locks the oven door, prevents most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked.
Based on the model number you have listed, there are multiple reasons for why your unit may not be turning up the temperature. One of the reasons is most likely the ignitor. Because it may be other multiple possibilities it is recommended that you contact a Service Specialist that can identify that the part that is malfunctioning.
Hi, Seems like you found out the hard way what I wrote about in this tip... Check it out it also contains some thing to try on how to unlock that oven..
