SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
SOURCE: what do I do if my cub cadet 1862 has no spark?
Try replacing the spark plug first, if still no spark, sounds like the ignition coil is going/bad.
SOURCE: No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
SOURCE: cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
