No but you can replace the ic chip on the ink cartridge see
http://farbtoner.com/resetchip-fuer-toner-schwarz-komp-fuer-dell-2150-2155-p-3781.html?language=en
or
https://www.amazon.com/TM-toner-331-0719-331-0716-331-0717-331-0718/dp/B00NM2CW2W
this video shows you how
https://www.youtube.com/watch?v=X8lGSaz6zO4
SOURCE: lexmark z1300 ink jet cartridge refill instructions
In order to refill the black ink cartridge on a Lexmark 1300 you need to purchase a 28a (18c1528)
cartridge. The 28 black ink cartridge is a return program cartridge and it won't let you refill it.
I found one at a site called computer friends for around $21.00. You can also google lexmark 28a ink
cartridge you can find them. I hope this helps. I've been frustrated with this problem also
SOURCE: Lexmark x5470 all in one printer-low ink level
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
921
SOURCE: Dell 926 Printer ink refill instructions
Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
SOURCE: I refilled my dell ink cartridges from Costco. Now
The ink is fine in the cartridge. The ink level indicator just thinks the cartrdige is still empty. You can ignore the message or turn it off all together. Just bring in your cartrdige for a refill when it shows signs of fading or streaking. Go to www.inkjet411.com for more help
SOURCE: Dear Adviser The Canon cartridges for
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Testimonial: "Thank you for your suggested solution. It was simple and above all it has solved the problem that I had with my Canon Pixma MP140. Thank you again."
