You can try.. turn on the monitor if it just shows the white screen then turn it off then turn on instantly. Even then, if the screen continues to be white (blank) then turn off the screen, unplug the monitor then again plug it after a minute and check.
You have deactivated the screen rotation option. Pull down your screen, press on the "more buttons" on your top right if you have to and press the "screen rotation" button do it turns active.
The unit has a fault on its power board and sustain board. It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
my motherboard is connected correctly but when i turn it on, the screen remains off and i put the bios_wp thing on the motherboard correctly but it still wont turn on and the processor fan turns on but nothing appears on the screen and the screen works well....same as my problem did you get then solution
