SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
SOURCE: dmtech remote control programming codes
I have been looking for the same codes myself and all I have found is:
0157
0159
0335
1994
2024
2031
0067
0312
0910
0208
0586
hope one of these work for you.
SOURCE: TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
SOURCE: I have DMTECH TV/DVD LT20X-1U23DMI ....
Assuming that by "working outlet" you mean something else like a lamp will work, then, the first thing is to make sure its the TV and not the remote control. If the power switch on the TV will power the unit, the the remote probably has dead batteries.
Assuming it wont respond to either the power swtich on the TV, or the remote, then look on the back of the set for a reset button and push it. Some units have a sort of circut breaker. It may be best to do this with the unit unplugged.
If none of this works, then try moving the cord around. If the TV will power up depending on the cord position, then you have a bad power cord, which is a pretty easy repair.
If none of this works, then the chances are that you don't have a Do it yourself kind of problem
SOURCE: Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Testimonial: "Plug and outlet are ok, well drop it off at best buy to fix. Thank you."
