SOURCE: memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
SOURCE: SD card full in spite of all files deleted - what do do?
OK, so if you want to delete the photos off your s.d. card, Simply open the 'terminal' application located in the utilities folder.
Then enter this into the box:
defaults write com.apple.finder AppleShowAllFiles TRUE
killall Finder
That will then make the .Trashes folder of the sd card show up!
Open it, go through the '501' folder, and there you go! Delete everything!
This happens because the card has it's own hidden trash.
Oh, and if you want to hide all the hidden files and folders again, simply open terminal, and enter THIS text:
defaults write com.apple.finder AppleShowAllFiles FALSE
killall Finder
Cheers,
Tristan
SOURCE: cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
SOURCE: accidently deleted files on sd card with hd writer
I had success with steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download sd card recovery software, recommended Asoftech Data Recovery (simply because i was using it and it worked) with link below
SD card recovery software
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your files.
