SOURCE: stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
SOURCE: washing machine stops mid-cycle
F30
DISPENSER SYSTEM ERROR
when the dispenser motor cannot be driven to its proper positon.
==========The following information is for a TECHNICION SERVICE(only)========
1.- Unplug washer or disconnect power.
2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
4.-Check dispenser motor for power rotation.
Was this helpful?
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
