SOURCE: aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
SOURCE: Have a AML 125 front
The door switch may be bad. You can test it with an ohmmeter. Do check the pump to make sure it is not loose or broken. Also check the drain and drain screen to make sure it is not clogged.
SOURCE: looking for user manual for
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/HOTPOINT-ARISTON/AML%20125-_M
Click on download the complete user guide. It would direct you to a new page.Rate the questions.Once done, a link for ' download ' would appear. Save the manual on the desktop.You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: I have ariston aml 125
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Testimonial: "I appreciate your prompt response"
