SOURCE: White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
SOURCE: Tornado 7 kg WA 90B9 washing machine top loading
you can order a new flap froom marcone appliance parts they have front door mail service alson if marcone does not carry this and they should you can go dircetly to samsung I have personally done tons of warrantly work for them ad they are more then happy to help there customers hope this helps
SOURCE: Could I "stack" a front
i would not recommend stacking one machine directly on top of another. there are various issues with weight, and movement due to vibration.
what you can do is built a solid "workbench" that you can fit one machine under, and then put the other machine on top of the "bench"
personally i would overbuild the bench, using 2" by 1" wood for the frame, braced and bolted to the wall for stability, and use a 1"thick worktop forv the top of the unit. on the top surface, i would also put a 3/8" wooden beading strip about 1/2" fron the outside edges of the worktop to stop the machine moving with vibration and falling off.
i have done this a number of times when space is limited, although i find it much easier to put tehr dryer on the top as it is the lightest of the 2 units.
hope this helps
SOURCE: Admiral top load 10.1 Kg 4 speed Combo has become
water does not stay in drum goes straight out?
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is
defective or the pipe connected to it is faulty.Generally error E9 means a
problem with your water pressure sensor. do you have water in the tub? Check
the sensor by pulling the hose attached to the bottom part of the tub and blow
on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
