t
torhemen tersoo Posted on Mar 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp AR 5516 displays error code H4, what should I do?
Myls Yu
Level 2:
Habit-Forming:
New Friend:
  • Expert 26 Answers
  • Posted on Mar 26, 2019
Myls Yu
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
26
Questions
0
Helped
5865
Points
103
Temperature error, use simulation mode 14 for reset the error , if not replace the thermistor, & use stabilizer to avoid problems due to power fluctuations.
5 Related Answers
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Aug 13, 2009
SOURCE: Sharp ar-c330 with an error code of H4-01. Any
yes your copier is problem fuser uniter
such as heater lamp or thermostator burning
Anonymous
  • 118 Answers
  • Posted on Aug 21, 2009
SOURCE: Sharp AR-M450 is showing error code ''H4-00''
You're getting a heat roller low temp detection on the fuser in your copier. The fuser is the device that provides heat and pressure to the toner to bond/fuse it to the paper (it's that black, rectangular box in the upper part of the body when you open the left-hand side of the door).
Chances are a peice of paper is jammed up inside and blocking the sensor (probably a small peice that tore from a page someone tried to pull from the fuser). That or the temp sensor is defective.
Anthony Karuku
  • 268 Answers
  • Posted on Mar 30, 2010
SOURCE: Ar 5516 display H4 error
This means that the fusing unit has a problem. Turn off the copier. Open the small side cover on the right of the fuser unit. You will see the wire connectors leading from the unit and carefully remove them.Open the three screws holding the unit and remove it, check the heater lamp continuity if out replace the lamp. Clean the thermistor and return the unit by reversing the removing process. Now try the code and it will work.
Xzx Cxc
  • 4 Answers
  • Posted on Aug 22, 2010
SOURCE: Problem for Sharp AR-5320 Black
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Anonymous
  • Posted on Aug 25, 2010
SOURCE: sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
3answers
My photocopier sharp AR 5516 is showing H4, what is the solution?
There's an earlier response to this question on fixya in Dec 4, 2012. Search "sharp ar5516 error code h4". It's the third hit down.
5helpful
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
9helpful
2answers
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
1helpful
2answers
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
2helpful
2answers
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
65helpful
6answers
Sharp ar 5516 printers error h5. h4
3helpful
H means heat, you need a new fuser.
9helpful
2answers
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
