Try to turn your ac without the remote. I think you can do that then make sure you are in cool mode. If the compressor does not run then you can check:
1. Overload relay. It is usually locate on the top of the compressor. If it dead then there are some reasons cause the dead. You need to be very careful before replacing it.
2. If the compressor runs then your remote issue.
SOURCE: Hi my bmw 523 model 1997 the air con fan is not
clogged fan with debris. bad resistor or 3. remove fan, run 12v directly to it to see if it spins. plenty of threads w/pics on how to do this.
SOURCE: my air con is not working.it has gas in the
You may have freon in system but compressor won't engage unless it's full under pressure. By jumping the the relay you're doing damage to compressor by running on low pressure. Have system evacuated and recharged to proper amount of freon - usually 4 lbs of freon
SOURCE: air condition homemaker model hmasw-h12a4/ea-2
homemaker H12A4/EA-2,dripping moisture from internal unit.I have cleaned drain pipe from unit,but don`t know where to go inside unit to find drain hole where it must be clogged. Do you have a diagram?
