For the updation of your mobile application there needed an internet connection on you mobile. Make sure that your mobile has internet activated . Go to mobile setting software version and there you will find software updation click it and you will get download option, download latest version and install it. Your latest version and updation has been done
try updating your mobile phone software. you can do it either from mobile or PC.
for updating from mobile menu>settings>settings>phone>update check for an available update in some mobiles also can be seen as menu>settings>phone settings>SW update
when updating from PC go to nokia pc suite/ovi suite >phone software update
If ur mobile is showing the not enough memory when music player is opened then here is ur solution!! This problem is due to software problem or due to a virus
there r 2 solutions for this problem....
1. Update ur mobile software using the latest Nokia Software Updater present in Nokia PC Suit (update).
This is ur own risk. U should have a stable internet connection and the
full charging of ur mobile battery as if ur mobile update is
interrupted, ur phone no longer works. So Be Careful.
2. Simple go to ur nearest nokia care center and give Rs.300/- if u
dont have warrent and get ur mobile updated. If u have warrenty, it is
free .
CAUTION: BEFORE UPDATING OR TAKING TO THE NOKIA CARE, PLEASE BACK UP UR
DATA PRESENT IN THE PHONE MEMORY. BECAUSE ONCE UPDATE STARTED, UR DATA
WILL BE LOST PERMINENTLY.....
You can update you mobile by connecting to you PC and install PC suite And you are using Samsung S5233S so you can download the PC suit from Online http://www.brothersoft.com/samsung-pc-studio-78015.html Use This link to download your PC suit and install it and then after installing just connect your Mobile to your PC using Data Cable Provided while purchasing the Mobile and then select in you Mobile as PC connection then you can see your mobile device in your PC in PC suite Software where right Download you can see a Update Mobile option So using that your can update your Mobile
if u want to update your nokia n73 mobile phone .firstsly download software NOKIA SOFTWARE UPDATER and than install it and connect your any nokia mobile phone and search update for connected nokia mobile.and update your device
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update the software download the nokia updater from below website
Select the phone model and it will show the updater.Exe software setup. Download and install it.
Open the installed software and click on start.Connect the mobile phone through USB cable.It will start checking the updates of the mobile and will start updating in your phone.
I recommend to update or reinstall the software please go to nearest NOKIA CARE and they will update or reinstall the software as required.They are more expirenced to do this process.If something wrong happens when you do updating it may make your mobile useless.So better to take to NOKIA CARE.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
You can also Update software by below steps Menu > Settings > Phone > Phone updates As of now no flashing methos is found for nokis 6300.Please go to nearest NOKIA CARE they will fash the mobile for you. Thank You
Please select detailedguide in the tabs.This shows step by step instruction how to update the phone software.Follow the steps you will be able to update the software.
Hi, I m using china mobile in india and I want to all chaina mobile update software . i need chaina mobile software updater. please give me answer immediatly. please reply in my email id.- [email protected]
