unlockjournal.comhttps://unlockjournal.com > Nokia
Method 2: Hard Reset/Factory Reset Using Master Reset Code (One) ... Step 1: Grab your Nokia 2760. Step 2: Now, dial the code *2767*3855#. Step 3: After dialing ...
Please note that hard resetting erases all the data on your device. Text messages, photos, videos, settings, everything will be removed in the process. So, don't forget to create a backup of your Samsung Galaxy S7 or S7 edge before proceeding.
Also make sure to juice up your smartphone to at least 60% or keep it plugged in during the process. You don't want to have your device turned off when you hard reset Galaxy S7 or S7 edge, or it will create further issues.
Factory reset Galaxy S7 or S7 edge the easy way
Open the Settings app.
Choose Backup & Restore > Factory Data Reset.
Now select Reset Device > Erase Everything.
Confirm the warnings and wait for the process to finish.
Once done, reboot your phone.
Hard reset Galaxy S7 or S7 edge using recovery mode
Power off your device.
Wait for a few seconds while your phone is shutting down.
1ST OPTION
Start by turninng on the device by using the Power key.Hard Reset
From the Home Screen go to Menu and then to Settings.
Tap Reset and then select Master Reset.
In the next step choose Yes to confirm the whole operation..
To begin hard reset process type in the following safety code: 1234.
2nd OPTION
At the very beginning hold down the Power button to switch on the deviceHard Reset
In the next step tap the following code in your phone: *2767*3855#
You should see information about resetting your phone.
Wait to comple the whole process.
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
I have the same tablet but can't seem to get the hard reset process to work..... hold in down reset nor the volume/power button process... please help!!!!
Only solution is to perform a hard reset but data in tablet will be lost.
Hard Reset steps are" 1. Power the Tablet off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process. 5.- Select all Erase contents and settings
The Tablet will complete the hard reset process and reboot into a factory default state.
Ok, I would say to reset your phone by code, just dial
Dial 3845#*54#
Now select Factory reset
But obviously it won't work because Android is corrupted.
I will leave this link which will explain how to hard reset your phone without using Android, and I hope it works. Hard Reset LG GT540 Swift
i made a hard reset to my i mate ultimate 6150 then it's blocked in part of it with out continue the reset process.I take off the battary then it stops on one screen in blue colour with imate word on it
A hard reset will erase everything on the smart phone. If you still see your data, then you were not successful in performing the hard reset. In that case, what you have done is a soft reset.
Carefully try one of these two methods:
Main method: 1. Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear. 2. Push the up button on the five-way to start the reset process.
Alternate process: 1. Similar to the hard-reset of the Treo 650. Remove the battery cover. 2. Press and hold the Red radio button. 3. Use the stylus to depress the reset button next to the battery. 4. Push the up button on the five-way when you get a prompt to "Erase all data".
