Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Use lithium (non-rechargeable) high energy batteries for best results. This is clearly a power supply problem. If it doesn't work, send it back for replacement. If the batteries are self-contained, ensure they are fully charged using the charger supplied with the camera. Remember, rechargeable batteries are only good for a maximum of two years. Cameras, in general, do not work well with rechargeable batteries as the voltage is less, i.e.; 1.25 volts vs. 1.5 volts per AAA/AA/C or D size battery.
it has a physical damage and its a serious problem. unscrew the housing and observe the damage area or lost connection. unless replace the display unit.
It sounds as a weak battery. Try to horn with the head light on to see if it can sound. 1- Have the battery recharged. 2- Clean off the cable terminal really well to prevent corrosion built up causing high resistance. If there is high resistance at terminals, there is not enough current flowing through the starter hence there is no starting. 3- If battery is good after recharged as well as horn could sound, but still not started, then the starter solenoid needs to be checked out. Good luck.
If E6 is displayed......Its dead. Bushnell doesn't have parts to repair it anymore. Go to the Bushnell.com website and find a unit that suits you. Call 800.423.3537 and they will offer you 30-40% off on a new one.
