Televison & Video Logo
Brenda Dyck Posted on Mar 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have programmed the remotes part way, then made a mistake. Do I have to start right from the beginning, again?
Joe Stanton
Level 3:
Genius:
  • Master 1,154 Answers
  • Posted on Mar 25, 2019
Joe Stanton
Master
Level 3:
Genius:
Answers
1154
Questions
5
Helped
315183
Points
3584
Its best to start from the begining............
1999 HONDA ACCORD FACTORY KEY FOB PROGRAM
Great news, you can program a 1999 Honda Accord Key Fob yourself. Simply follow these instructions:
Obtain all remote transmitters for this vehicle and read the instructions prior to programming.
Entering programming mode will erase all previously programmed remotes for this vehicle. You must have all remotes available for programming including working ones.
  • Enter vehicle and close all doors
  • Each of the following steps must be completed within five seconds of completing the previous step. If you take longer than five seconds or make a mistake, you must start the entire procedure over.
  • Insert the key into the ignition, hold one remote in your left hand with additional remotes close by. We recommend taking remotes off the key ring to perform the procedure. When the instructions say to press the LOCK button, you should press the LOCK button on the remote for approximately one second then release it.
Perform each of the next three steps in order, then repeat all three steps two more times for a total of three times each.
  1. Turn the ignition to the ON position, marked II.
  2. Press the LOCK button on the remote.
  3. Turn the ignition to the OFF position, marked I. (Do steps 1-3 three times)
Next, turn the ignition switch to ON position, marked II.
4. Using the same remote, press the LOCK button again. The door locks should cycle indicating the vehicle has ENTERED programming mode.
5. Using the same remote, press the LOCK button again. The door locks should cycle indicating the vehicle has PROGRAMMED that remote.
If you have other remotes to program then repeat step 5 with each additional remote one after another. Step 5 must be completed within ten seconds for each additional remote. You may program up to three remotes.
6. Turn the ignition to OFF. Test all remotes.
If your remote has a trunk button you will need to hold that button down for several seconds for that function to operate.
I need to find out where the valet/override button is located on my car....trying to program a new keyless remote
1. Insert key into the ignition and turn it to the On or ACC position, turn off radio. (do not start the vehicle)
2.Press and hold DISP button on radio until settings is displayed.
3. Press Seek until FOB PROG is displayed .
4. Press Prev or Next and BEGIN will be displayed
5. Press DISP and programming will begin when PUSH FOB is displayed. Press and hold Lock and Unlock together until vehicle chimes. This will signal successful programming. May have to hold buttons up to 20 seconds. Hold Lock and Unlock on additional remote until vehicle chimes again.
6. Exit programming mode. Scroll to Exit and press DISP to exit programming.
If you don't have the original radio, it can be done with a scanner.
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Remote keyless programming
This procedure clears the transmitter codes and creates new ones, so you must program all remotes at the same time, even if one or more is already working.
Enter the car, and close all doors.
Each of the following steps must be completed within five seconds of completing the previous step. If you take longer or make a mistake, start the entire procedure over again.
Insert the key into the ignition, and hold one remote in your left hand. Whenever the instructions say to press the LOCK button, you should press the lock button on the remote for about a second and then release it.
Perform each of the following three steps in order, then repeat all three steps two more times, for a total of three times each:
1. Turn the ignition switch to the ON position, marked II.
2. Press the LOCK button.
3. Turn the ignition switch to the Off position, marked I.
Do this three times!
Next, turn the ignition switch to the ON position (II) for a fourth time.
Press the LOCK button again. The door locks should now make a cycling sound, indicating that the system has entered Programming Mode.
Press the LOCK button one more time to program this remote. If you have other remotes to program, press the LOCK button on each one in turn. The door locks should make the cycling sound after you press LOCK on each remote. You may program up to three remotes, and they must all be programmed within ten seconds of each other.
Turn the ignition off and remove the key. The remotes are now programmed and may be tested.
If you've got a trunk/hatch release, hold the button for this function for a few seconds.
How to reprogram my 2005 honda pilot key fob
The great news is you can program your 2005 Honda Pilot Key Fob yourself. All you have to do is follow these instructions:
Most remotes can be self-programmed. If these procedures do not work, you must have your remote programmed by a professional automotive locksmith or dealership.
Procedure #1
Obtain all remote transmitters for this vehicle. Entering programming mode erases all remotes, so all remotes must be programmed during this procedure.
  1. Turn ignition to ON (ll). (ON is the position just shy of starting the vehicle without cranking engine)
  2. Press and hold the valet/disarm button located between the AM/FM and CD/TAPE button. The vehicle will respond by locking and unlocking the doors, indicating the vehicle is in programming mode. (You must continue to hold the valet button until instructed to release)
  3. Within five seconds, press the LOCK or UNLOCK button on the remote. The vehicle will respond by locking and unlocking the doors, indicating the vehicle has programmed that remote.
  4. Within ten seconds, Repeat step 3. for all additional remotes to be programmed.
  5. Release valet/disarm button to exit programming mode. Test all remotes.
Procedure #2
Need to reprogram remote
Quick fix try and leave batteries out for a day to see if it looses all memory. Also try uninstalling software removing all user settings, then reinstall and try again.
3helpful
Factory garage door opener
If this is the 3 button HomeLink Transmitter usually centered overhead above the rear-view mirror, this should work:
While the engine is turned off follow these steps to program up to three channels:
1. Decide which one of the 3 channels (one of the 3 HomeLink buttons) you want to program.
2. Press & hold the desired button through step 3.
3. When the HomeLink indicator light begins to blink slowly(this may take up to 30 seconds), hold your hand-held garage door remote about 1 to 3 inches away from the buttons & then press and hold the button on your garage door remote. Continue to hold both buttons until the indicator light on the HomeLink begins to flash rapidly(this may take up to 90 seconds).
If it still doesn't work, make sure the batteries in your garage remote are not weak, and try again moving the remote back & forth and left & right or turning it upside down while programming.
Also note HomeLink will not work with older garage door openers, especially not with ones manufactured before April 1st 1982.
2answers
Broken key fob
bought second hand fob now being reprogramed
2answers
Install program from CD
just open the cd drive, insert the install cd, and then you should see an autostart/install routine begin. may have to wait a few minutes, but it will start.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
