The green light flashes twice then a short pause and repeat all the time
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
SOURCE: Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
SOURCE: 2003 ford ranger airbag light is flashing code
46--- Driver Pretensioner Circuit Resistance High
That means the buckle in you driver side seat belt system has failed. It has an explosive device called a pretensioner in it which is designed to pull you into place microseconds before the airbag deploys. That component has failed and has deactivated the airbag system. You will need to replace the 'buckle pretensioner'.
But before you do, please get real familiar with the system you are working on before you cause additional damage, hurt yourself or deploy the bags accidentally.
http://www.airbagsolutions.com
http://www.airbagsolutions.com/vehicles_list.aspx
http://www.airbagsolutions.com/demo.aspx
SOURCE: Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
