I can not find a remote control for my Slingbox 500.
They have the original here: https://www.remotecontroldepot.com/500-SlingBox-Remote-Control-Original
This is a replacement for the original.
https://www.google.com/shopping/product/7898940491087492140?q=Slingbox+500+remote+control&client=safari&hl=en-us&biw=320&bih=445&tbs=vw:l,ss:44&prmd=sivn&prds=num:1,of:1,epd:8386569001855149188,paur:ClkAsKraX4gK3_SS9e9ZSpTGU4YW9IJKKcn_NZBjsRsh82t08uhjIOhp3tmgjgNxQ9je41jlN_X3jMEDOk4t08HBs0R_Y21IJH8ykhcw29VT4gytXxNr8F-mDBIZAFPVH7291hLWdhez53LRv5Umzt6MjhCgIA,prmr:1,cs:1
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
SOURCE: omnitech jumbo universal remote control and vizio hdtv
Here are the instructions for auto code search from the Omnitech manual:
Automatic Search
There is another way to set up your controller, that does not use the brand code lists. You can let your
controller search through all of its available codes automatically in order to set the connection to the
target device. To do this, follow these steps:
1.Turn on the target device.
2.Point the controller at the target device and press and hold the Code Search button for around 3
seconds, until the LED light stays red.
3.Next select the type of device the target unit is by using the Cable/TV/VCR/DVD/Sat Buttons (i.e. if
it is a TV that you are trying to control, press the TV button). The LED light should then blink once,
then stay red.
4.Press the On/Off button on the controller slowly and repeatedly until the device you are trying to
connect with turns off. (Note: the LED light will blink each time you press the On/Off button). When
this happens, press the ENTER button in order to store the code and the LED light will turn off.
SOURCE: Universal Remote used to control Digital converter box
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
SOURCE: jigimate tv-universal control code needed
Does anyone know the code for the Digimate TV DGL321?. My remote is lost and I would like to use my RCA universal control, but cannot find the code.
SOURCE: cant programme Phill Jumbo Universal remote controller
it would take a week to type the book and code's.
best bet> forget the jumbo bit.google universal remote control. they are all much of a much and get info from any
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy. Or, type in the brand name to
your device into its search box, and press "Enter"
Codes to check are: 009.003.006.019,072,087
