SOURCE: My Tv says Keys locked
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
SOURCE: How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
ur problem will be solved.. rate me!!!!
thank u
SOURCE: child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
SOURCE: i need to switch my tv to input without a remote
Hi
please use the menu button in your front panel then search the video, Air, or Cable selection!
Thanks!
SOURCE: how to off child lock off in my panasonic tv without a remote?
You can't unlock it without its remote control.
Turn
on the TV and grab the remote. In most cases, you will need the original remote
to unlock the TV if you aren't sure of the unlock code. If you don't have the
original remote, you will need to purchase one.
Look
at the screen. If you see a blank screen with a red key on the bottom of the
screen, press 'Function' and 'Mute' at the same time. This should unlock the
channel. This is an option for people who want the TV to stay locked but, want
to be able to bypass the lock to watch a certain show or channel. All other
channels will remain locked and the TV will fully lock when it is turned off.
Unlock
all of the channels on the TV by entering the factory reset code. There are
three main reset codes that TV manufacturers set. These are 0711, 6688 and
3308. Try each one until you find the one that works. This will reset the TV to
original factory settings. When you do this, you will loose any information
that you have stored in the TV, such as favorite channels, automatic timers and
the clock. You will have to go through the full initial set up.
Call
the technical support service number in your owner's manual if none of those
codes work. A technician can help you troubleshoot the television because the
problem may not be the locking control. When you call, make sure that you have
the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
