Compressor hpco or (High Pressure Cut Out) means the high side pressure has went over the limit the machine has been set too. The safety is there to protect the compressor. If the machine is water cooled, the water flow has most likely been interrupted. So often the machine was moved for cleaning and the wheel is on the water hose. If the machine is air cooled, Either 1. the fan has stopped, 2. the condensers are dirty or 3. It's just too hot where you are trying to run the machine.
to run duel screens you will need a graphic board that has 2 outlets
I run a nvidia board and it has a dvi and vga outlets connected to 2 monitors
open up the control panel and go to display
that will show 2 screens and they will be identified as 1 and 2
the printing will be for one screen and it will say -make this my main screen
further down will be a dropdown box that will have extend screen
click on that
as for the screen size or pixal settings click and drag the slide button up to the top and click on apply
any way in that display section you can move and click on different settings to get what you want, always apply to fix the settings selected
it will come back with a message --do you want to retain the settings and if you are happy --click on yes
regardless of what you choose , you can always reset at a later time
HPCO is an acronym for High Pressure Cut Out. The most common causes of this code are either an issue with the fan in air-cooled equipment, or an issue with water flow in water-cooled equipment. MOST of the time, someone has mistakenly shut off water to the unit, or moved the machine and pinched a water line with the caster wheel. A restriction at the expansion valve is a possibility but unlikely unless the refrigeration system has been opened recently, possibly to replace a compressor or other component.
If you would like to discuss your issue further with a technician, call 1-800-879-7839. http://www.softseveparts.com/
