Put your big boy pants on and google your question and find answer.
About 26,100 results (0.57 seconds)
https://www.youtube.com/watch?v=Xf8cxt2DWpI
I'm sorry to trouble you with my silly question Mr. Pack, but I'm a girl, just trying to figure out how to fix our washing machine myself as my hubby fell 12' off a roof at work 10 months ago and is staying in a care facility for another two months until he heals up. I know that this isn't your concern, just forget that I even asked.
SOURCE: lg wm2277hw washing machine
sorry to say it but i think you still have a faulty hall sensor.
Try another one and send the last one back as being faulty.
It means the motor gets the power but the hall sensor stops it dead in its track
SOURCE: hall sensor
No. Actually, the Hall sensor, part number 6501KW2002A, is covered by a 7 year part warranty.
SOURCE: LG LE error. WM2277HW Have replaced the Hall Sensor and ran
As long as that Tide HE is not 2x or 3x concentrated, that would be the maximum amount of detergent for a large, heavily soiled load. Lighter soiled and/or smaller loads should be about 1 tablespoon. If 2x concentrate soap, use only half that. The reason this could cause an LE error is that suds between the inner and outer drum will cause excessive drag on the inner tub, with the possible result of an LE error. I'd try to run a load on Sanitary, heavy soil level, with no clothes, and a washer cleaner such as Affresh, Washer Magic, Whirlaway hot tub cleaner, Smellywasher cleaner, or Tide washer cleaner to remove any possible build up of soap residue from the outer tub area.
Sometimes, cycle selection/ loading level/ load type can cause LE errors. Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
Another possiblility would be a loose electrical connection dealing with the Hall sensor, at the sensor, the control board, or (much more unlikely) the wire connecting them.
On rare occasion, the main control board can be at fault, but generally, replacing the Hall sensor does take care of the problem. (over 90% of the time)
Testimonial: "Right on with the solution...After fully disassembling the washer ohming all the wires checking all connections. It turns out a loose hall sensor."
SOURCE: LG washing machine---wd-8015c------not spinning and
check water pump filter .... bsc appliances 07779933829 spares or repairs
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall Effect sensor is used in these washers which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when there
is an issue with the motor or when the Hall Effect sensor sends wrong signal to
the control. Conclusion is you'll have to check both motor and hall sensor and
replace the part# that is bad, usually I have seen the sensor going bad. Please
get back to me if you have any other questions.
Kevin
