Wifi is xfinity
SOURCE: LG KC910 connecting wifi to my home internet
I had this problem, My wirless router is using WEP Authentication with a "Shared Key". I had to change this to either Open or Automatic on the router.
SOURCE: LG Incite: Connect to a multiple-user WiFi network
To enable or disable Wi-Fi
To set up a Wi-Fi connection
To edit a Wi-Fi connection
If you select a secure network, you may have to enter a network key that is provided by the network administrator.
To delete a Wi-Fi connection
To change Wi-Fi settings
If it is necessary, ask the network administrator for authentication, encryption, and network key information.
SOURCE: ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
SOURCE: LG PRADA KF900 - WiFi connection error
i was facing the same problem for a while......... finally got the solution. go to 1 Browser then 2 settings 3 profile your phone must be activated on ewap select wifi and it will show activated.
Enjoy surfing!!!!!
br
[email protected]
SOURCE: please help me unlock my
yes, you can get the unlock code for your LG model mobile, through this site http://www.theunlockspot.com/lg-ku990/rs10wp9/
It has the best instructions and easy methods for unlocking your LG model mobile phones...........
