SOURCE: Hi I lost my manual for sansai 8 in 1 universal
It would have been helpful if the DVD player model was available. This document has codes for most of the models.
http://www.remotec.com.hk/photos/support-doc/8363%20Code%20list.pdf
SOURCE: I need a code for my highlander DH-2816 hd set top box to suit the sansai urc-L969 universal remote
Sansui URC remote control have no set-up code to this device; I can see. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: sansai urc l969 codes list lost
I was struggling to get Sansai URC-L969 working also. After a looking through a ton of sites like this one, I found a similar model of Sansai Universal remote user manual here:
URC 969 Instruction Download Sansai
It lists all the IR codes as well as how to use the damn remote. I could get none of the codes to work (which might be down to the fact that there is no "0" key, A key that is used in EVERY code).
I got mine working using the Manually Search Code instructions on page 2 of these instructions. Another hurdle was the "TV1" button seems not to be programmable for me - It would not "twinkle" as the instructions says it should. The other preset buttons (VCR, CBL, DVD, TV2, TV3, SAT, AUX) were programmable.
In case the link gets moved or anything, here is a quick run through the instructions:
1. Hold "Set" then press the button you wish to program - I used "TV2"
2. The Set button stays lit, press it again so it's flashing
3. Turn on television and point remote at it and press the Power button slowly until the television turns off.
4. Your remote now has the right code selected, press the "TV2" button once more to save the configuration to the button.
5. If the other buttons don't work as expected (volume etc), repeat the process of cycling through all the configurations again and just ignore the first one that turns off the television.
Hope that saves someone the headache I have had the past two days while looking for information on this brand of remote. No one seems to know what they're talking about when they answer these questions.
GOOD LUCK.
-L
SOURCE: How do I use learning function SANSAI URC L969 ? l do not have maual
How to use learn function on sansai URC L969 universal ...
www.fixya.com/support/t25610267-use_learn_function_sansai_urc_l969
Mar 27, 2015 - Posted on Mar 27, 2015.
Hi, I just bought the Sansai URC-L969 8 in 1 universal - Fixya
www.fixya.com/support/t9376242-just_bought_sansai
Jun 3, 2011 - Hi, I just bought the Sansai URC-L969 8 in 1 universal remote, ... the manual) i have put in all the codes and it just doesnt seem to work. ... Turn your device back on and try all the remote's functions to ensure they are working
