SOURCE: replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
SOURCE: kenmore microwave model 721.62644200
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: kenmore 363.62709200 microwave lights wont turn off
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If
there's no obvious removable cover over the bulb (and the owner's
manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
If
If not, chances are
If you don't have your
instructions, please reply back with your brand and model number.
On a
counter top model,
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
driver (such as a T20H type or GTXH20-100) may be needed.
screws.
Bulbs can be had locally in most
We're
