Increase the volume on the TV and/or your connected media device (streaming player, Blu-ray player, cable or satellite box, etc.). Check the audio settings on your TV and connected devices. Turn off and unplug your TV and connected devices. Inspect the TV cables and ports, then check the ones on your devices as well.
Check Mute. Make sure the sound on your TV isn't muted. Push the Mute button on your TV remote. ...
Adjust Volume. On your TV remote, use the Volume Up/Down buttons. ...
Sound Menu. Push the Menu button on your TV Remote.
THE COMBO WHEN YOU HIT PLAY SHOULD BE AUTOMATIC AND DISPLAY PICTURE AND SOUND ON THE SCREEN---THIS IS LISTED AS A TV-VCR COMBO SO IF dvd hooked to one of the rear inputs (some are also on front on some models) in the menu you select that input and should see the picture and hear the sound from the DVD.
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Here is the manual:
http://www.symphonic.us/pdf/om/SC313D.pdf
Follow the instructions for connecting a cable box to connect your converter box. Front panel buttons can be used to make menu selections if you do not have a remote.
to get best picture and sound you need to use HDMI connection. This is normally if you have a HD cable box. If you don't have a HD box, use the coax connection directly from the cable line. On your TV, hit the menu button, use the arrow up/down to select manual channel search, select cable and hit enter. this will scan all the digital and analog channels.
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
most like the amp on speakers wwent bad best u can do add seprate samsng sterio suround system or ect form dish cable box to sterio direct for tv sound or rca outs on tv if those sstill work
you have a bad tuner you can replace it or use vcr if you still have one around. hook it up with av cable like your ps2 and hook your cable to it and use it to change channels. If you want to replace the tuner it will require soldering and you will have to order it somewhere. i would try partsore.com. The tuner is the metal can the cable goes into inside the tv.
