SOURCE: Adjust valve clearances 1987 toyota corolla
Im assuming its an 4AGE!?
http://www.ae92gts.com/ae92gts_valve_adj.html
And here one of my favorites...;)
http://www.billzilla.org/4agstock.htm
SOURCE: want to know what is the valve clearance of bajaj ct-100 m/c?
get the engine on top dead center, take valve caps off turn over engine slowly until intake valve just closes u will be close to top dead center there. then i use a small long screwdriver i put in sparkplug hole and turn engine very slow when piston just startes to go back down i adj valves. intake valve 3 thousands and ex valve 5 thousands
SOURCE: Valve tappet adjustment
well, I can see ur message has been here for quite some time. Most probably you got the answer to ur request.
I just did the valve clearance on the engine of my SJ413 that has the 1000cc engine of an SJ410 :
When cold: 0.13mm Intake and 0.18mm Exhaust
Engine sounded well and worked fine after that.
Enjoy
Mehdi
SOURCE: how to adjust valve clearance on a 1999 sunfire
There is no valve adjustment for that engine, Hydraulic lifters, You might remove the valve cover and see if you have a rocker arm loose
SOURCE: How do you adjust the valve clearances on the
motor has to be turned over counter clock wise to top dead center T or I should show up in the inspection hole. I bought one had a horrible rattle and I thought it was a major problem but turned out to be loose valve adjustment. When turning the motor counter clockwise don`t back up if you go too far just go around again. I set mine to 3 thousandths intake and 4 thousandths exhaust
Intake Valve Lash8 0.127 mm (0.005 in.)
Exhaust Valve Lash8 0.178 mm (0.007 in.)
Hi Vianney Lortie, please add details in the comment box? Need a model number, some kholer engines don't require adjustment.
