My fire button would blink red 10 times if I held it down.. it’s not no update or upgrade what I did is I screwed the coil to the top piece of the tank... Take your coil out and put it back in but screw it to the bottom part of the tank first then your glass then the top of the tank... I had to get rid of a refilled tank because this lmao..
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
SOURCE: i have wega KV-HR36 red light flashing 10 times
Any malfunction associated with a flashing light usually indicates a
circuit problem or defective component. Unfortunately, the days of
taking off the back cover of your TV and replacing a defective tube or
fuse are long gone. Proper servicing will require troubleshooting
procedures that can only be performed by a qualified electronic repair
facility or professional television repair person. Ask for an estimate
and a realistic appraisal of whether the set can be adequately fixed.
Depending on the age and condition of your TV it may not be cost
effective to repair.
SOURCE: my tv will not turn on. the red light flashes 10 times then pause
Most likely a bad Y-sustain board.
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
SOURCE: 50 inch Panisonic TH-50PZ85U, wont turn on and has red light flashing 10 times
thats usually caused by a blown thermal fuse on the transformer and the 10 blinks appears. I can assist but will need to do it via email you can contact me at [email protected]
