This is a common problem of old DVD players and the cause is a loose loading belt. You can hear the loading motor running if you put your ear to the set during OPEN operation.. The solution is simple. The loading belt is to be replaced, if you have the belt and know how to replace it.
Good luck.
SOURCE: DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
SOURCE: DVD Tray in computer not opening
there should be a small hole on the front of the tray that you can push a pin in from and it will eject the tray. if its stuck and you still need to hit it, would be best to use your warranty to get it fixed or take it apart yourself and make sure noting is blocking the tray from opening. you may have to take the tray apart and put it back together to get it to work normally.
SOURCE: Need to reset samsung dvd vr357
With the unit on, hold down the FFW and RW buttons TOGETHER. Do this in front of the unit, NOT ON THE REMOTE CONTROL.
The unit should either open the tray or say REST OK on the front panel.
Hope this helps!!
SOURCE: display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened.
There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system.
Unlocking Procedure 1
To turn off the Dealer
Lock function, follow these
steps:
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2
steps
Note: Repeating
Unlocking Procedure 3
steps
Note: Repeating
the two steps above turns Dealer Lock on again.
Unlocking Procedure 4
steps
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
SOURCE: My Samsung DVD VR357 won't play any disc. I tried
Could they be plugged into a reciptical connected to a light switch?
