SOURCE: Connecting the LE46A556P LCD TV to the HTZ310R Home Cinema System
You need to be connecting the TV and the Sky Plus to the HT box via optical (toslink) for full surround sound. As you only have one optical port on the HT, I would suggest buying a Optical selector such as this one. I would also suggest looking on avforums more more help. I use it for most of my questions if ever i need any help.
Hope this helps!
SOURCE: No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
SOURCE: lh300 sky box works with scart but wont work with
on your tv, have you selected the correct mode on your source button? eg, AV1, AV2 , PC, and HDMI
SOURCE: Can hear the game but cant see it
ok i have had his problem my self turn off the system from the back then turn it on again hold down the touch sensitive power button in the front to turn it on but dont take your finger off the light will turn red after a while and your resolution will be reset then just touch the power button again to fire it up and a green screen should come up asking you if you want to switch resolutions just click no
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
