SOURCE: Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
SOURCE: Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
SOURCE: Unable to get sky on panasonic tv
You cannot drive both from a single cable. You require a dual LNB fitted to your dish (replacing the single LNB). This has two cables out , one to sky and the other to the TV. If you have your own dish this should not be a problem.
SOURCE: No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Does this work on module th42pwd8
Panasonic TV model above
Can you show me how to connect sky and wot I need for a panasonic th42pwd8
Connect a hdmi lead to the back of sky box and other end to your tv
Does the TV have to be on a setting has not working like that
TV has to be on same setting as hdmi slot that lead is plugged in. What if connected to hdmi1 then hdmi1 needs to be aelected
Is it possible to watch sky on this TV Wen it is set up
