SOURCE: DVD player is not able to detect WD 320 GB hard drive
Try reformating the drive with FAT32 file system (this is the default facotry mode).
Thanks,
Siva Kaza
SOURCE: how do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
SOURCE: I plug in the USB
First, try using a different USB stick. If that doesn't fix the problem then your new tv is either faulty or the tv operating system has a bug.
Check the LG website in your country to see whether there are any firmware updates available. If not, then return the tv for refund or exchange, but make sure to try your USB drive on any replacement set in store as it's highly likely to be a bug in your model which will affect all of the other examples as well.
SOURCE: I own a LG Plasma
The USB port on the TV might not have enough power to power the external hard drive. Can you try putting a movie on a USB memory stick instead, and see if that works?
SOURCE: my usb flashdrive wont play
May be your hitachi tv is not supported with the file format that your usb flashdrive movie is using.
