How do you turn off the closed captioning
SOURCE: closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
SOURCE: closed caption will not turn off on toshiba regza 46 hdtv
Try unplugging the TV for at least 5 minutes .. then try again
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
SOURCE: turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
SOURCE: spanish closed captioning stuck on Tobisha 46RV530U
i have polaroid tv and can not shut the closed caption off
Hi Jerry Efird, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? How long has it been on? Are you watching cable or satellite or other
