SOURCE: Blank black screen Nikon coolpix 5700
Contact Nikon. There is a known componant problem with this camera (see Nikon onlin support page ). It will be repaired free of charge even if it is out of warantee.
SOURCE: Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
SOURCE: black screen unable to take pixs
Call This number 1-800-645-6689 select 1 for US then press 1 for tech support. They will give you the information and procedure that you need to do for the replacement.
SOURCE: Trying out new 4G SanDisk cf memory drives in Nikon Coolpix 5700
There is a simpler solution. Just do this: 1. format the card in the camera 2. Connect it via card reader to your PC 3. Copy a little over 2Gb of data to the card - to a different folder 4. Put the card into the camera 5. It should work now... This way you can save some valuable data to the remaining 2 gigs of the card. Note: This has been tested on Nikon Coolpix 5400, but should work on 5700 as well
SOURCE: Lexar 4gb flash card not working in Nikon coolpix
You can go up to 2gb, bit no bigger (it's the file format used). 1gb is the optimum.
