Cameras Logo
D
Diane Kirkman Posted on Mar 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Found minolta Dimage7i in back of parent's storage cabinet. batteries left in have leaked on the hinged door and would like to replace to see if camera will still work. great shape.
Here2HelpYou
Level 3:
Master:
  • Master 592 Answers
  • Posted on Mar 24, 2019
Here2HelpYou
Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152559
Points
4122
Put on proper protection for your skin/eyes, then remove the old ones, clean with some general cleaner or cola(yes like Coca Cola or Pepsi, etc. as it eats corrosion), then replace the batteries with new ones and see what happens!
5 Related Answers
saturno65
  • Posted on Mar 25, 2008
SOURCE: Minolta 5000i
i need owners manual maxxum 5000i
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Apr 04, 2009
SOURCE: How to remove and replace door hinges on new shape VW Beetle
you cant their welded on
Anonymous
  • 3361 Answers
  • Posted on May 23, 2009
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Anonymous
  • 3361 Answers
  • Posted on Jan 06, 2010
SOURCE: hinge, oven door #822144
Pull up on the door to remove it from the hinges.
Remove the pan drawer on the bottom. Remove the spring from the hinge to be replaced. Remove the hinge mounting screws. Remove the hinge.
Reverse this process to install the new hinge.
Anonymous
  • Posted on Aug 04, 2010
SOURCE: Maytag Skybox Broken Door Hinge
The part number your looking for is
Model-Maytag MVB1976AAB
Part number is 11001194
1helpful
We have a Horn Sewing Machine Cabinet and two of the door hinges have broken. ( Horn 270 Hinges ) Do you know where we can buy replacement hinges ?
quality hardware shops have small hinges
cabinet makers have addresses of cabinet hard ware supplies
or on our horn cabinet there are 2 long hinges ( piano hinges from a hardware shop) that go the full length of the doors
Sep 11, 2016 • Ovens
How do I replace the bottom socket where the door hinge slides in
I assume you mean the hinge that is on the cabinet and not the door? If its the door part that has failed, you will need to get a new door. If its the cabinet hinge, some of these are screwed onto the cabinet from underneath the fridge. Others however, are mounted inside the cabinet and are not really designed for replacement. Ive fixed a few over the years on different brands where the plastic hinge has broken but it can be a bit messy. The cabinet needs to be carefully peeled or bent back on the bottom corner of the fridge to access where the hinge is mounted. Unscrew the hinge and if you are lucky, the Manufacturer has these as a spare part. If not, the only way is to go to a hardware or cabinet parts store to try and source something that will suffice. Do NOT be tempted to put a normal gate or door hinge onto the fridge door and screw it onto the cabinet. Inside the cabinet especially around the edges are whats called "mullion heater" pipes or in older fridges, mullion elements. If you screw through a pipe, you will lose the gas and fridge will be shot. If you screw through an electrical mullion heater, there is a danger of electrocution.
1helpful
Singer 6110
If it can be attached, there will be a set of screws/hinges on the back side of it.
I actually modified a sewing machine cabinet to be able to place my machine inside for storage, on its side. When sewing, I have
the modified board on the hinge and the machine sets on top of that. When not is use, cabinet looks like a "table" cabinet.
More info, contact [email protected].
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Amana SXD23V refrigerator leaks water underneath the side where the refrigerator door is evey time I try to get water out of the dispensor. I found a plastic tube on the floor about an inch long then...
I believe your water line or the union nut just behind the kickplate may have come loose. Lets see if we can find a repair kit and get you going again. Depending on where the line is broken or leaking will depend on just how much you will need to do so if leaking at the union nut please disregard removal of door.
WARNING
To avoid risk of electrical shock, severe personal injury or death; disconnect power to unit before servicing, unless
testing requires power. Discharge capacitor through a 10,000 ohm resistor before handling. Wires removed during
disassembly must be placed on the correct terminals to ensure proper grounding and polarization.
sea_breeze_2.png Here are the instructions from the manual below.
1. Open door and remove all storage buckets.
2. Remove toe grille.
NOTE: Shut off water supply before performing Step 3.
Have a bucket ready to catch spillage from tube.
3. Loosen water-tube clamp screw. Loosen plastic
water-tube union nut. Pull water tube away from
union nut and through tube clamp.
4. Remove screw that mounts door closure to top
surface of bottom hinge.
5. Close door.
6. Remove screw holding top hinge cover in place.
Remove top-hinge cover.
7. Unplug wiring harness connectors. Remove ground
screw and ground wire from top hinge.
8. Remove top hinge and hinge bushing. Pull hinge and
bushing off wiring harness.
NOTE: Hinge shim is glued to top of cabinet and must
be left in place.
9. Lift door about 3 inches to bring lower hinge bushing
up, off hinge pin.
10. Set bottom edge of door on protective pad. Remove
hinge pin (with door-closure tab) from bottom hinge
bracket.
11. Reverse procedure to rehang door.
For plastic tubing click HERE
and for a simple snap on coupling I want you to call to insure you get the correct size and snap on union.
  • 1-800-269-2609, 8 am to midnight ET, 7 days Repair Clinic are very helpful and friendly and will be happy to answer your questions. I also will be here to answer any questions you may have, Thanks, Sea Breeze
  • 1helpful
    Whirlpool top load washer won't wash after filling
    The hinge on the left side activates the lid switch. The hinge will have to be repaired or replaced.
    Use a putty knife or a old CD to slide under the control panel on the right and left sides,where the control panel front meets the washer top.
    This will release the clips that hold the control panel to the top cabinet.
    Fold the cabinet to the rear.
    Unplug the lid switch in the top of the cabinet on the left side.
    Remove the brass clips holding the cabinet to the rear panel.
    The cabinet will come off so that you can access the underside for the hinge and lid switch.
    2helpful
    2answers
    Leaking from the lower right hand side during rinse cycle.
    I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
    Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
    1helpful
    2answers
    Door
    your oven needs two new hinges on the affected door. I have seen this problem many times, the internal stops on the door bend over time and cause the door to not close all the way. They are fairly easy to replace, you just have to split the door open to repalce em. Hope this helps!
    Top Minolta Cameras Experts
    ZJ Limited
    ZJ Limited
    ADMIN Andrew
    ADMIN Andrew
    Tony Parsons
    Tony Parsons
    Are you a Minolta Camera Expert? Answer questions, earn points and help others
