SOURCE: No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
SOURCE: Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
SOURCE: screen lookes like colores separating
Hey try this check under setup do you have the convergence option. if you do not you may have a simple little repair. Check out the article in the tips and trick section of this site intilted "the fl231 problem"
SOURCE: vizio 50 in.the plasma has a vertical blue line thru the light
make sure that the blue screen setting is turned off
