Ovens Logo
Jacqueline Vincent Posted on Mar 23, 2019
Kenwood CK405 Duel Fuel Range Cooker - The large oven is not working, it isn't heating on any settings, oven, grill, fan oven and the indication light does not come on. How can I resolve this please?
Sam Stothers
Level 1:
  • Contributor 27 Answers
  • Posted on Mar 25, 2019
Sam Stothers
Contributor
Level 1:
Answers
27
Questions
Helped
13514
Points
42
I have fix a few of these it's the selector switch the one that you turn to select which part of the oven you want to use it is a bit costly for it but if you can strip the top of the range it is easy to see and you will see on the selector at the back the 2 wires the copper strip will be a purple colour in stead of a copper colour you can fit a beko selector to the selector switch on urs and just move the 2 wires to it works a treat and only cost about £10
4 Related Answers
Anonymous
  • 174 Answers
  • Posted on Aug 04, 2010
SOURCE: My90 duel fuel range master
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
paulcharmbur
How-2-Repair.com
  • 746 Answers
  • Posted on Jan 30, 2014
SOURCE: main oven not heating up
Kenwood Oven not heating? How to replace a Kenwood fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
paulcharmbur
How-2-Repair.com
  • 746 Answers
SOURCE: kenwood ck405 - main fan assisted oven not heating up
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Kenwood element How to Repair Home Appliances
alfredschrad
Al Schrader
  • 438 Answers
  • Posted on Mar 21, 2018
SOURCE:
Sounds like a switch or connection issue. Suggest obtain a volt-ohm meter and test everything.
My Smeg oven stop working Fan inside lights and clock are working but Thermostat and program lights as well heating is not working.Any ideas what could be a problem
Check if the oven timer is on auto mode. If it is, turn it on to manual mode .
Remove the power cable from the outlet and wait for 20 minutes. As you plug your oven back in, the oven timer should reset as well .
Hold the timer buttons down at the same time to reset the timer .
Meter the thermostat out and see if it's open circuit .
Take the top off and inspect the selector switch and see if there are any signs of burning on the switch .
How to Repair ' Smeg duel fuel range cooker A1-7 Oven not working. (how-to-repair.com)
Nov 20, 2023 • Smeg Ovens
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 • Ovens
Model SA392EB
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 15, 2013 • Smeg Ovens
2answers
Main oven not heating up but fan is working on kenwood ck405 oven
Oct 13, 2010 • Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
Aug 04, 2010 • Ovens
1helpful
2answers
Kenwood ck405 - main fan assisted oven not heating up - grill working, fan working but think it might be the element - how easy is it to replace element?
Feb 17, 2010 • Ovens
1helpful
2answers
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Please rate my solution.
Thanks.
2answers
Smeg oven
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
