SOURCE: High School Musical game - language
I got this from the disney.com/videogames web-site. It works.
1. Put in game and turn on.
2. At Menu tap the bottom listing (Op...)
3. Tap the top listing until English appears. It goes through a bunch of languages.
4. Then hit the arrow on lower left of screen and you are all set.
SOURCE: change language of my o2 comet from german to english
Hi
i have the same problem. Have you the solution?
Regards
SOURCE: Xerox Phaser 8560 - Changing Menu from German to English Language
To select the default language on the Control Panel:
To select the default language using CentreWare Internet Services (CWIS):
If you are talking about the driver menu you have to delete and reload the driver with the english
SOURCE: I want to change the language on my navman from German to english
First of all the language was Finnish and not German.
I managed to get a translation from Finnish to english for the word
kieli (Language).
Then i went to the system menu and selected kieli, then englanninkieli
then pressed enter, this changed the language to english.
I did not have to do a factory reset.
Thank you for your trouble.
Regards
Noel
SOURCE: Need to change language from german to english.
If you are talking about one of the Casio QT6xxx's then you need to.
I . All peripheral devices and terminals of this cluster should be turned off.
2. Connect all of the peripheral devices (such as printer, display etc.) to terminal.
*In case of wire inline:
3. Connect all terminals by inline.
*In case of wireless inline: QT 6000 or QT6600 models
3. Connect Wireless LAN card.
Operation:
4. Turn on all peripheral devices of a terminal.
5. Turn on this terminal while pressing and holding the initialize switch and then release.
6. Next the screen will say push the INIT (initialize) switch to start IPL.
After releasing the key
The IPL will take a few minutes to copy over.
When it is done, Pick the Language you need. enter"20000" (U.S.)," l0000" (other area:English)," 40000"
(other area:German)," 50000" (other area: French)," 60000" (other area: Spanish) and
press the <OK> key.
I will be making a video of this procedure this week, so visit us @ www.casiohelp.com to view it.
