Water Heaters Logo
Anonymous Posted on Mar 21, 2019
Replacing sensor on whirlpool water heater - Whirlpool Water Heaters
Jim Akins
Level 2:
Champion:
  • Expert 201 Answers
  • Posted on Mar 21, 2019
 Jim Akins
Expert
Level 2:
Champion:
Answers
201
Questions
9
Helped
64124
Points
445
Water heaters only have a top and bottom thermostats which seldom go bad. Heating elements wear out most often. If you are running out of hot water too quickly kill the power drain the tank and remove bottom heating element using a special large socket. Visual inspection should tell you if it is melted. If it is ok check the top heating element. If the heater was on and the tank not full the top element will go first. Elements never operate at the same time
Whirlpool Gas Water heater N50T61-403 Senor failure error
Whirlpool sold the AO Smith brand flue damper, and the atmospheric models ... both models have different honeywell gas controls...
Error codes, service manuals and troubleshoot appear following link:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#honeywell
There is no specific service manual available for the flue damper series in 2019
How to test flammable vapor sensor lockout on whirlpool gas water heatermodel nd50t122-403
You could clog up the screen on bottom of water heater... and this would cause FV system to trip because of overheated combustion chamber... then clean arrestor screen and push reset button located on front of combustion chamber to get water heater working. Of course you might have to replace parts to restore functionality.
Or pour some gasoline nearby and see if the water heater explodes, or if the FV trips. I would think this to be unwise.
Contact Whirlpool
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
How to replace temperature sensor in Whirlpool water heater
Whrilpool will send information.
Copy following link for resources, including images showing temperature sensor (thermister):
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://waterheatertimer.org/images/Whirlpool-energy-smart-part.jpg
Remove cover on outside of tank.
The foam insulation is very stout, and must be cut back to access sensor located above each element.
Insulation must be put back when finished.
After insulation is cut back, it appears you can remove the sensor... I am assuming the wiring can be unplugged, or spliced. It is not possible to replace wires that run between sensor and top of tank because the foam insulation is too tight and wiring is not inside a conduit.
Add a comment and say what you discover.
Where can I get the new sensor unit for Whirlpool water heater (N40S61-403)?
1) Call whirlpool
1-877-817-6750
Need model and serial number located on label on side of tank
2) Copy following links for troubleshoot and repair resources, including service manual by type of gas control valve.
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Get parts sheet from manual that arrived with new product.
4) Otherwise, neither Whitlpool or Craftmaster.has up-to-date product manual, parts sheet, or service manual, rendering their sites near useless for many owners.
Whirlpool site has 'troubleshoot and repair' section, but this is NO help for serious DIY repair.
Water in basement in flood that covered the lower element. When power was turned back on, the green light on the top of the heater was blinking twice. When I hit the reset button, it is now blinking...
Yes sensor should be replaced along with lower element.
1) Manufacturer's say that flooded water heater should be replaced: Call homeowner's insurance company.
http://waterheatertimer.org/Flooded-water-heater.html
2) Brand of water heater is not known, but it could be the American or Craftmaster or Whirlpool energy-smart electric with control box.
3) With energy-smart:
1 flash is start-up failure, and 3 flashes is sensor failure.
The moisture probably shorted element and/or lower sensor.
4) The moisture inside tank will take long time to dry out, especially since the foam insulation is wrapped tight. To dry out element and sensor, you have to remove cover and insulation over element, but if you leave insulation off and run water heater, then the sensor is exposed to cool outside air and will not read temperature inside tank.
Plus a wet water heater is electric shock hazard.
5) Add a comment for more free help.
6) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Whirlpool Energy Smart Water heater - light is solid green then every now and then blink a couple of times then go solid again.What does this mean?
2 flashes = high water temperature (the water heater comes set at 120, and you can set it lower or higher)
3 flashes = sensor failure (temperature sensor similar to a thermostat on regular water heater)
4 flashes = upper element
5 flashes = lower element
Links below are for Whirlpool manuals
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
The water heater is working right now.
If the elements go out, they are available at any hardware store.
The temperature sensor is easily replaced and can be ordered from Whirlpool.
You might want an extra temperature sensor on-hand so repairs are not delayed.
Link below shows the product in detail.
Let the water heater do its job until it fails.
4helpful
2answers
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Top Whirlpool Water Heaters Experts
Paul Carew
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
