It sounds like the wiring harness on your Kymco mobility scooter may have become reversed or disconnected. To fix the problem, you'll need to open the battery box and check the wiring for any loose connections or reversed wires. If there are any, you can reconnect them properly and the direction levels should return to normal. If that doesn't work, you may need to replace the wiring harness or contact a qualified technician for assistance.
Common Electric Scooter Problems & How to Fix Them ...
https://fluidfreeride.com/blogs/news/electric-scooter-troubleshooting5 Common Wheelchair Faults and How to Fix Them ' Ideas in Action ...
https://stechfordmobility.co.uk/news/wheelchairs/5-common-wheelchair-faults-and-how-to-fix-them/What is CDI? What does a CDI box do? - RevZilla
https://www.revzilla.com/common-tread/what-is-cdi-what-does-a-cdi-box-do
SOURCE: need to change mobility scooter controls back to right handed
Open up the front shroud (unhook batteries first) and switch the wires going to the throttle pod, its just 2 thin wires and if they were switched already you will probably be able to switch them back. The throttle pod is what the thumb throttle lever is hooked up to.
