Problem on kymco mobility scooter
Check and make sure you havnt wired the battery back to front?
Buy fildena 25 Online is contain of sildenafil citrate. Know about fildena 25 mg uses , Price , How to take , Side Effect , How to use fildena. A renowned pharmaceutical company called Fortune Healthcare manufactures Fildena 25 Reviews . cheap Fildena 25 , buy fildena online Fildena 25mg
SOURCE: need to change mobility scooter controls back to right handed
Open up the front shroud (unhook batteries first) and switch the wires going to the throttle pod, its just 2 thin wires and if they were switched already you will probably be able to switch them back. The throttle pod is what the thumb throttle lever is hooked up to.
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
SOURCE: my 2005 50cc kymco cobra racer scooter does not start
i have fire and new cdi ran find for 2 days but hard to start now it will not start
SOURCE: Kymco Vitality 2t 50 won't turn over. When I
Take your spark plug out of the cylinder, reconnect it to the ht lead and place it on to your frame if you see a spark then your coil is fine, try a new spark plug, if there is no spark get a new coil and plug.
Remember there is a 2t and a 4t version of the kymco vitality and the spark plugs are different.
