Sewing Machines Logo
Sarah Boakes Posted on Mar 21, 2019
Turning sewing machine on where is switch - Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
2answers
Why doesn't the feed dog come back up?
Most machines have a switch that changes the sewing machine to free arm. Usually in front of the storage compartment.
You also need to have the length of the stitch above zero.
1helpful
Feed dog won't come up on my viking #1, is there a switch? tried turning hand wheel , is there a switch
you didn't put a model number in the question, yes, it's possible there is a switch or lever. if you have a manual it should have the information in it. but without being able to see the machine, I can't say for sure. try looking on youtube for a video. the next best thing I can suggest is calling a sewing machine shop in your area and ask them if they are familiar with the machine and ask them about the feed dog lever.
Sewing machine stops sewing
what type of sewing machine do you have, and have you tried turning it off, then switching back to the sewing position. you may need service, or an external bobbin winder.
Why is my singer stitch not turning on ?
Do you have it plugged in or is the foot unplugged? One time my electrical had popped off check brakers. Does switch feel loose when you touch it? if so switch could be bad unlikely but happens every so often. Did you forget to turn switch off or on. ?
Bernina 1090 s
if turning the sewing machine off and back on again does not clear the problem, the taking the sewing machine in to be checked would be a good idea to see if there is something wrong with the motherboard or if the machine needs some type of adjustment.
Why isn't the sewing machine wheel turning
it could be a problem with a belt , motor, a loose or broken part
taking the machine to be checked is the best solution
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
