Televison & Video Logo
Teresa Frerking Posted on Mar 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Magnavox MPD850 with remote. How do I open the remote control to replace the 3V lithium battery?
Level 3:
  • Magnavox Master 6,688 Answers
  • Posted on Mar 21, 2019
Cindy  Wells
Magnavox Master
Level 3:
Answers
6688
Questions
0
Helped
3529937
Points
21745
You don't have to open the remote exactly. You have to pull the battery compartment out. It's in the middle of the bottom edge of the remote on the back. There's a slight ridge that you should use to help you grip the compartment cover while you slide it towards yourself. Just make sure not try to pull too far off the center of the battery compartment.
This is shown in the manual on page 12. ManualsLib has this page of the manual here: https://www.manualslib.com/manual/97776/Magnavox-Mpd820.html?page=12#manual .
I hope this helps.
5 Related Answers
A
Anonymous
  • Posted on Jul 13, 2008
SOURCE: sound but no picture
I have the same problem. The little white popup button on the upper right of the bottom of the unit when it's open is there to cut off the video if it's closed (i.e. in the event it's plugged into a television). My white button won't pop back up... could be the problem with yours. Wish I had a solution.
Anonymous
  • 10 Answers
  • Posted on Jan 21, 2009
SOURCE: Remote Control Code for Magnavox mdv-430 dvd player
Yes, a Philips replacement remote should be an excellent choice for your Magnavox DVD player, since they are sister companies. I am using the inexpensive Philips URC US2-PH5DSS and it works well. Your Philips remote will come with a page with all manufacturer codes listed by the type of device. Or you can visit the Philips URC code lookup website at www.urc.philips.com.
The codes listed for Magnavox DVD players are:
0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598 You'll have to try them one at a time to see which works best for your player's functions.
Mr Tech Geek
  • 133 Answers
  • Posted on Jul 27, 2009
SOURCE: Will any 3V Lithium battery work for the Scout
Any good CR2 battery should work. Try this.....remove the battery cap, then pull out the spring a little bit, Dont break it. Make sure the battery goes in Positive end first. reinstall cap and see what happens. If you can, measure the battery voltage.(2.9 to 3.2 volts)
good luck
MTG
Chi Chu
  • 8457 Answers
  • Posted on Apr 22, 2010
SOURCE: I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Ironfist109
Iron
  • 3018 Answers
  • Posted on Jul 21, 2011
SOURCE: need to replace the 3v
  • Hello, I have just received your question and wanted to give you an update. In looking at the service manual here is the battery you are needing - 92916717 Battery 3 Volt 0.255 Amp. I am tracking down where to get one and looking at the schematic on installation instructions so please allow me a few minutes for this. I assure I am working only on this at the moment.
Regards, Tony
How do i replace the battery?
Remove the four screws from the back of the remote.
Gently remove the front half of the remote.
Remove the circuit board from the remote.
The battery is located on the back side of the circuit board.
Replace the battery with a CR2032 3V Lithium Battery.
Carefully reassemble the remote to ensure the water proof seal.
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
3helpful
Magnavox MPD850 dvd player won't play, only display no disc
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer read the disc, but you can buy a DVD cleaning kit that might breath more life into the player, if no! cheaper to replace the DVD player.
4helpful
3answers
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
8helpful
Replacing memory battery garmin gps 75
The battery inside is a panasonic 3v Panasonic
Battery, Lithium, 3v, 190ma, Coin
cell
884-0301 BR2032
You need a clip too
Keystone Electronics
Battery Holder, Coin-Cell; 20
mm; 0.896 in.; Glass Filled
Nylon; 1; 1 AWG
Remove battery pack. Open unit by the six small screws in the back. The coin battery is in the bottom right (mine had a blue cover) The original ones are soldered/pressed in. Replace with the holder and rewire. Cheers
2answers
Top Magnavox Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
