Transmission,drivetrain,engine,wiring,fuses
00-06-01-026L 2018/10/03 Engine Replacement After Severe Internal Engine Damage - Replace Intake Manifold 07-06-01-016E 2018/07/24 Information on Internal Engine Noise or Damage After Oil Filter Replacement 16-NA-222 2018/07/23 Information for Engine Concerns Resulting from Lack of Scheduled Maintenance, Improper Service or Aftermarket Calibrations 06-00-89-031E 2018/03/28 OEM and Remanufactured Engine and Automatic Transmission/Transaxle Identification 06-06-01-010D 2018/01/31 Information on Close-Coupled Converter and Engine Replacement PIP3343F 2018/01/09 Possible Engine Oil Leak Due To PCV Freeze-Up PIE0439 2017/12/04 Engineering Information - California Only - Pilot Initiative - Urgent Service Action Required 01-06-01-011J 2017/11/30 Information on Engine Oil Consumption Guidelines 01-06-01-028C 2016/04/05 Engine - Knocking on Cold Start Explanation 12-06-01-008B 2015/03/09 Vehicle - Engine And Sub Systems Flushing Info. (CANADA) PIP5169 2014/01/07 Engine Controls - DTC P0300 After Engine Repairs 11-00-90-001B 2013/05/21 Engine - dexos 1(R) and dexos 2(R) Oil Specs/Information 04-06-04-054E 2012/08/06 Engine - THIS BULLETIN HAS BEEN CANCELED 08-06-01-008A 2009/07/27 Engine - Drive Belt Misalignment Diagnostics 05-06-01-010B 2007/09/28 Engine - Sealant Usage/Procedures 06-06-01-019B 2007/06/12 Engine - Coolant Loss With No Visible Leaks 07-06-01-002 2007/03/05 Engine - Revised Connecting Rod Bolt Torque 06-06-01-026 2006/12/22 Engine - New Exhaust Manifold Bolts/Torque Specs 06-06-02-026 2006/12/22 Engine - Revised Exhaust Manifold Bolts/Torque Specs. 06-06-04-046 2006/09/12 Engine Controls - MIL ON/Misfire/Misfire DTC's Set 06-06-04-037 2006/08/04 Engine Controls - MIL Function During I/M Testing 02-06-04-015A 2006/03/07 Starting System - Engine No Start/No Crank Condition 05-06-04-029A 2005/06/24 Engine - Rough Idle/Misfire/MIL ON/DTC P0300 05-06-01-014 2005/05/09 Engine - Oil Leaks In Extreme Cold Temperatures 05-06-04-024 2005/03/17 Engine Controls - Revised DTC P1172 And P2636 04-06-04-057 2004/08/11 Engine Controls - Start/Stall/Poor Driveability 04-06-01-013 2004/04/01 Engine - Serpentine Drive Belt Wear Information 03-06-04-062 2003/11/19 Engine Controls - Revised DTC P2135 03-06-04-032 2003/06/16 Engine Controls - MIL ON/Low Voltage DTC's Set 03-06-04-031 2003/06/01 Engine Controls - Revised DTC P1125 Information 03-06-04-033A 2003/02/26 Engine Controls - Revised DTC P0336 03-06-04-015 2003/02/01 Driveability - Revised Engine Cranks Won't Run Diagnosis 03-06-01-003 2003/02/01 Engine/Transmission - Flexplate/Flywheel Replacement 02-06-01-038 2002/12/01 Engine - Knocking or Lifter Noise 02-06-01-028 2002/08/01 Engine - Crankcase Flushing Recommendation
Any or all recalls on the 2003 Chevrolet Silverado 1500
