Washing Machines Logo
ismail khadir Posted on Mar 21, 2019
My ifb senorita acqa VX 1000 rpm 6kg washing machine have a problem After one wash machine will not start for a 24 hrs .s0me times it will take two days for the second wash?
5 Related Answers
Anonymous
  • 74 Answers
  • Posted on Feb 17, 2008
SOURCE: Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
A
Anonymous
  • Posted on Jun 13, 2008
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on May 27, 2009
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Anonymous
  • Posted on Jul 25, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Anonymous
  • Posted on Feb 23, 2011
SOURCE: Beko A+A Class 1000 rpm
i would check the lint trap for foriegn bodies, e.g hairclips, hair bands, screws etc as these can cause the pump to stop working, be aware that water will immediately come out of the trap when you loosen it, good luck
I have IFB SENORITA DX 5.5. It sw off after 1-2 min run. IFB tech told to replace PCB. Pl help 1. Circuit diagram of the PCB 2. Cost of the PCB 3. Any other thing to be checked? Thanking you Dhananjay
  1. IFB SENORITA DX USER MANUAL Pdf Download ' ManualsLib https://www.manualslib.com/manual/845703/Ifb-Senorita-Dx.html
    View and Download IFB Senorita Dx user manual online. Senorita Dx washer pdf manual download. Also for: Digital 5.5kg.
1helpful
2answers
In IFB front washingmechain AC h1 error is coming what to do
that error occurring due to high voltage in your residing area. We believe IFB Washing Machine protects your machine by tripping. We have GA 400 Voltage Stabilizer to buck or Lower your upcoming Voltage from GEB. It has Capacity of 12 amp and 15 to 20 Voltage up /down capacity. We are sure this GA 400 model will solve your problem. You can Call on : 9722658052 or 9427347880 Thank You
Ifb front pcb diagram
What is the model number of your unit?
Top IFB Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
