SOURCE: Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
SOURCE: my phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
SOURCE: nokia 6120 shows offline how do i get it online
I just did it with a little help from the first response. However, exact steps are: Go to SETTINGS then go to PROFILES. My cel options are NORMAL, SILENT etc. Go to NORMAL then....gees, since I have it on line again, I can't remember if you go to ACTIVATE or CUSTOMIZE. One of those two options will tell you, "YOU ARE OFFLINE, WOULD YOU LIKE TO GO ONLINE" Of course you will choose ONLINE and VOILA!
