SOURCE: Mastercraft compressor - one pancake type tank ... need pressure
You do not need to use factory replacement switch. Mos t universal pressure switches are set to shut off at 120-130 psi. You will need to check the placement of the unloader valve (1/4 line from check valve) and the quantity of ports as some switches have only one port and others have 3-4. Check ebay for good match and low price. Good Luck
SOURCE: my pancake compressor runs fills air tank then ar discharges under switch
Especially with the twin stack models, the weld between the air supply stub and the tank can crack which leaks air on the tank side of the pressure switch/regulator. Had two HL5402s with same problem.
